post-18854-1141958863.jpgpost-18854-1143190549.jpgpost-18854-1143190593.jpgpost-18854-1143190637.jpgpost-18854-1143190678.jpgpost-11183-1125314016.jpgFor sale
One set of 4 x 16 inch x 7 inch Stagea rims with Nankang 225/50/16 tyres, the tyres are less than say 13% worn.
The 4 rims are in A grade condition, previous owner(s) have put a couple of small marks on them but normal for the age.
Actually, upon further inspection (24/3/06) the insides are mark-free, showing they have NEVER taken a hit, and have had 1 small scrape one 2 wheels upon parking (one wasnt worth taking a picture of, truely).
Really are in ExCeLeNt condition
Brendan (PM me)
edit: pics added 24 March
Edited by Tangles
https://www.sau.com.au/forums/topic/109046-stagea-rims-tyres/
$500 or best offer
Perfect condition.
Tyres alone cost $125 each for 4 last August, done less than 4000kms on them since then.
Bargain - look awesome on a 'Line.
OK - here is the deal.
$400 for the complete set of 4 wicked mags with awesome near-new tyres
$200 for the mags only
$220 for the tyres only
bargain - add shipping & handling of course, would prefer local Adelaide pickup
What is the offset and how much to send to Brissy ? Brad
Hi Brad
The markings on the inside the rim say 16x7 40
so I 'assume' offset is 40
I paid $96 for TNT Express freight of 17inch R34 GTT rims & tyres from outer sydney suburbs to Adelaide, so I assume from Adelaide to Brisbane would be approx. $120 plus Id need to buy some bubblewrap to wrap 'em securely.
So I guess $500 including packaging, handling, and freight, to Brisbane. Pm me.......................
Brendan
OK - Been offered $450 for the sale of the 4 rims & tyres, including delivery to Sydney.
I believe I'll take it unless YOU (ie you the reader of this blurb right now!) offer me a better deal today.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
