AWESOME TEAMWESTSIDE BBQ Pics from Saturday @ Akira =)
If anyone needs to get in contact with me, my mob is
0404 85 7474. and no this is not my bootycall hotline.. thats my
other number.. Minh and I are usually together with Friski on
saturday... Silver.. i'll trade you mine if you trade me yours!
  • Replies 182
Im sorry guys but I feel very violated here. :chop:
George you have taken my virgin exhaust and hammered it.
On the way home I noticed a slight rattle to my car, checked underneath to find that 1 of the bolts on my exhaust was loose :D a fix with a spanner and it was all good again.
You musta rammed it good :uh-huh:
I just wanna say thanks to everyone who rocked up at such a
short notice and made it a great event..
Also extra thanks to the following people who made it possible..
Frank and Mark, thanks for organising the drinks and eski's
Goran for all the cuttlery
Minh for organising it and driving me around in the morning.
Mini GTR for the bbq
Ed for bring and chopping the onions
And sorry we couldnt post this one because it was only a spur of the moment thing.
Next BBQ wont be far away as there have been quite a few PMS my way asking when the next one is for the new guys to come and Join TWS and say hi.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
