baught a T04 wat do i do... wat do i do
i just baught my self a T04 turbo of some dudes my cousins deals with
its rebuilt and is about to get hi flowed
now what do i need tyo run this on my stock r33 gtst i got an idea..
i think new computer bigger injectros
full exhaust system dump pip ..cooler BOV..
am i missing anything??
would i need to get custom headers??
am i missing anything important
https://www.sau.com.au/forums/topic/10997-baught-a-t04-wat-do-i-do-wat-do-i-do/
lol
i dont nee dto get it checked out cause his my cousins best mate and they suply th eturbos for my cousins work shop when ever young p platrer slike me boost there nissan silvias to high
but its been rebuilt so its all cool and yeah ive seen it
no cracks all sweet all the internal runing gear stuf have been changed as well
TIME TO SPEND BIG MONEY I THINK CREDIT CARD BALANCE IS ON $0
cheap cheap mate
hahah
itr use to be a on VL which was accedently set on fire and rolled down a big hill up near kilor
and the turbo flew out of the car and landed at my cousins work shop
lucky i guess hahah
i payed for da rebild kit which cost 125.60cent to be exact
but i gave him 130
he can have a 4 buck tip
so in english, your cousin's mates, brother, best friends, uncles, brother, sons, relo saw a fully sick vl, stole it, ripped all the good parts out of it, burned it and rolled off a cliff!!
now he selling all the parts to feed him drug addiction!!
hahahahha
no no no
my cousins mates brother laws cousin had a VL turbo insured for 12 grand so he striped the VL sol dog his parts to my cousis mate and my cousin tol dhis mat ei was interested in a turb sio he goes here have it.. my sisters bf is a cop and i dont wanna get cauight with it so he gav eit to my cousins who gave it to another mate who is rebuilding.. well should be finished rebuilding it for me..
make sence
all true story
no drugs ivolved
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
