  • Replies 74
Posted Images
im kinda sceptical on ur time, as nos generally removes 2 seconds
i think i saved the replay no nos fitted at all to the car.
with nos you should be able to take off more than
2 seconds on such a large track
*edit, typo*
I did the ring in 5:45 something in the R32 GTR Calsonic... Fully worked with nos and a long 5th. No spins, and a generally good clean run. I had holidays for 4 weeks :)
*edit, typo*
Got a split?
...and maybe post a pic of the screen for these 'ultra' fast times :dry:
  • 3 weeks later...
'97 R33 GTR Vspec
8:37.421
Stock w/ sports med tyres
Slides more than the 32 i reckon so i think i could better my R32 time easy.
BTW im only doing 2 laps with each car as it not the shortest track in the game lol. first is to get the feel of the track with the car and then i see if i can beat that one.
Edited by Freddy Kruger
thats exactly what I do, you need to set a time and a ghost car to beat :D
'99 R34 GTR Vspec
8:24.817
i rate the r34 :ermm: definetly holds the road better than the r33. plus it was red so it gained an unfair advantage with speed :sick:
might do a 350z next or the gtr proto? dunno...
Modified Mines R34 GTR
6:54.775
i could get quicker i reckon with changing the gears and suspension as it topped out at 348kmh on the straight and slid like a mule round some corners...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
