  • Replies 74
Posted Images
2nd lap round the 'Ring just then in a stock R34 GTR, no driving assists, manual, standard tyres - 8:03:316
wasn't a very clean lap, i could probably shave another 2 or 3 seconds off that....
righto. i suck... i accept the challenge :)
nah im over gt4 i really need some new games :P
Modified Road Car (r34 GTR N1 (Buntworx special :D)), 1 lap, 7min02.367sec
Nah, that'll be classified as in the Skyline GTR section and your about 38seconds off the pace of Kamikaze, sorry
I am getting the Nissan R92CP as I type this, with B-Spec Billy :(
oh :( didnt know lol thought was for pc anyone know wat it retails for in wa havnt touched my ps2 in months
GT4 i think is around $50-$60 now....I was in Target just before and I saw it there, not in a platinum case yet.
Just had 2 laps with the R92CP and did it in - 5m26.871sec so I have a long way to go yet. I tried without the 1158hp turbo mod and did it in 5m29 so I can do it faster but beating 5m09 will be tough.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
