hey guys ive upgraded to electronic boost controller i have no need for this t-pce i got off here
still in perfect condition asking 20bucks for it
item is in mt gravatt contact / sms me on 0422 19 19 13 \thanks
https://www.sau.com.au/forums/topic/110828-skylines-australia-boost-controller/
