I went to get
H3c globes form a place in Melb that is one of the only to have these as Oz shops (auto1 etc.. ) don't have these yellow sort of globes.
I need 1 as one of mine blew... and since then the model has changed so i need 2 of them.
now the price for each of these was... $120 each.
$240 ALL up... for two yellow style globes.
There has tobe a place i can get them cheaper?
i'd pay upto 50-60 bucks
https://www.sau.com.au/forums/topic/11101-ridiculous-price/
Not R32...
i got an R31 with the projector head lights.
The globes were PIAA H3c
Auto one... repco... bursons... don't have the yellow ones in that model.
Probably becuase they are illegal... but i want them anyway cause the light they gave off was better than Oz Spec white globes...
The plain white one for mine were about $10.
https://www.sau.com.au/forums/topic/11101-ridiculous-price/#findComment-183418
H3C - yeah i looked everywhere in adelaide for these and asked on the r31 forums. i wanted some blue tint ones :D
only could either get the navara standard globes or there are apparently multicoloured 'autotechnica' globes which apparently are shite (dont last long)
https://www.sau.com.au/forums/topic/11101-ridiculous-price/#findComment-183606
I was wondering when this would come up.
H3c is the same as H3, except it has two prongs at the back for power, instead of one wire that a H3 globe has.
From the baseplate forward (Towards the bulb) They are the same, even to the point that a H3 globe will fit perfectly where a H3c sits.
All you need to do is solder a earth wire onto the baseplate, then plug it back into the stock connector.
I have fitted H3 PIAA Plasma blues into a R32 projector lens that is meant to have H3c globes. Was a 10min job.
EDIT: I know what I am talking about, yet it did not sound right when typed! Lol.
https://www.sau.com.au/forums/topic/11101-ridiculous-price/#findComment-184327
Dragon...
Thanks dude!
MOST helpful.
I will probably do that... but i've got a guy who knows someone in Japan and he's trying to get some H3c globes.
If he can't get them then i'll probably just change it to H3's then.
And i'll take them if i do.
I'll let ya know
https://www.sau.com.au/forums/topic/11101-ridiculous-price/#findComment-185730
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
