I have a 100gb Toshiba brand notebook hard drive for sale.
Speed: 5400 rpm
Interface: Serial ATA
Absolutely brand new. Never been formatted. I won it at auction but it had the wrong interface for my notebook... :)
$200
G'day do you have picture of it?
when you say its wrong interface with your laptop... it doesnt reconise the HD more than 60GM or 40BG??? is that the problem?
thanks
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
