they buy u what u want ;) *big hugs to the other half* :D
Inside the box -
Parts laid out -
the body (fresh out the box unpainted still)-
close up of parts -
the instructions -
I bought some paints i didnt have so i can paint it soon (ive done models in the past).
The detail is pretty good, it has a full interior (dash etc.) and rubber wheels etc...i can paint it my choice of colour, but im going for the metallic black.
i'll post pics of the build. :drag:
https://www.sau.com.au/forums/topic/111262-bithrday-prezzies-56k-sucks/
I bought mine from Hobby Habit on Main Nth Road.
They have a large range of others (which ive got my eye on) including 33gtr's, Pennzoil Nizmo, Calsonic, 34's, 180's, gtst 33's, silvias (s13/s15). The damn paint costs about the same as the model was to buy, but if you have built some in the past it works out u only need a few colours at a time.
Go to the tamiya website to see the full catalogue.
Oh yer, Hobby Habbit have one i saw im getting next - The Homer (includes a small homer) :drag:
How much are they?
The model as you see it is about $34
If you dont have the paint, it becomes expensive, as it uses 18 different colours. I only had to buy a few colours as ive done previous models in the past, and the more kits u buy later, the less paint u need to buy.
Happy B'day. :)
Looks nice, when will you get around to putting all the bits together?
Not going to be like the 'real' R32 is it... You know.. that hks manifold sitting shed.... the bonnet and guards that are sitting in the shed.
hehehe lol
Happy B'day. :mellow:
i had a awsome model of a purple 34 gtr on my 21st bday cake that my mum got, its pretty detailed, and cost like $80 from some hobby shop, ill post pics when i get a chance :) (i tried 2 return it n get blue but they said no :happy: )
Nice present, looks nice. I thought I would let you know that I have a !/12 scale nizmo R32GTR model. It has rubber tyres, working steering, mesh grill, hinged doors,turbo's brake disc's and even metalic badges . I have been to lazy lately to even start to assmble. lol This one was $300 though and limited to a few hundred models. I got it for my birthday to.{two years ago}This one is mainly assemble with screws and springs and will take time to assemble {many hours} .Its about 375mm long. Got it from complete hobbies main north rd brahma lodge.
I have other models to finish first 1\32 A10 thuderbolt , 1\35 apache helicopter etc .
If you want a look, I might be able to post pic's or maybe catch up with ya so you can have a look.
Any way nice present! :happy:
Straightline Automotive on Port Road also has these Tamiya models, I think he has a couple of 32 GTRs down there at the moment. They sold like hot cakes at the last Extreme Horsepower show.
He also has some of the Initial D already built black 32 GTRs which are pretty hard to find if you can't be bothered building one up.
I just got a different brand 32 GTR that i am building up. Mine doesnt have an engine in it though :D
Here are some pics of a 2004 34 Nismo Race Car that i built last year
Edited by Whiplash
  • 1 month later...
couple of update pics :)
Havent been working on it much lately....but meh...
(images attached for now as sau hosting is down atm) will edit later...
Engine bay still have brake stuff to go in, and painted.
Body is being sprayed and decals put on the exterior...as well as lights etc.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
