ey all, just thought all of you out there with darker coloured cars might be interested. tryed the new tech wax today on my black 33 that i recently had cut n polished (swirl marks). this wax took all the swirl marks outta my car n gave it a darker, deeper appearance! much reccomended! has anyone else used it and if so wat did you think?
brett
https://www.sau.com.au/forums/topic/111291-maguires-tech-wax/
if you are a member of www.offtopic.com, head over to their "That'll buff right out" section and have a read of some of the product reviews the guys there give (There are a fair few professional detailers in that forum, who do FANTASTIC work... main one is ScottWax)
Try AutoGlym Ultra Deep Shine. Based on their Super Resin Polish, it does a friggin awesome job especially on darker coloured cars. AutoGlym is made in the UK, and I can highly recommend their whole range of car care products :D
Havent used the New tech wax ( I assume thats from the NXT generation range?) but ive been using their products for a fair few years until recently......
Switched to Zaino, the difference is amazing. Cost is a little higher but the results are jaw dropping.
Well I have used the Meguiars NXT generation tech wax stuff, and it is easily the best product I have ever used personally. My car is dark blue but it is very bright underneath - you can only really see this in sunlight or under certain lights.
My paint job was very neglected when the car arrived from Japan over a year ago, and I have tried so many different things on it that it wasn't funny. But this stuff was amazing. My paint went from being blotchy (the brightness underneath was blotchy, not the surface), dark, dull and boring to being even and absolutely brilliant. It is really bright now and just looks fantastic. The shine produced is also much better than any polish i've ever used. The best $40 i've ever spent. I would happily recommend this product to anyone with a dark car. I also notice that the bottle version of the wax (this is what I used) is larger than normal bottles of polish.
This product gets nothing but praise from me :D
a friend of mine has a black r33 s2. went to autobarn and asked which wax is the best... the sales guy tried every single wax they had on his car. and meguiers tech wax was the best.
my r33 is white so it probz doesnt matter what wax i use... but the tech wax is what im gonna buy!
After using the wax, will the swirl marks on a black car just come back after several washes?
I just dont want to spend time on it only to have the swirl marks come back anyway.
basically, yes
the swirl mark are always going to be there, the wax will just create a temporary layer that disguises them for a while.
Maquires Clear Plastic Polish is some good Sh!t also, S2 33 headlights come up a treat, not to mention the the rear lights!
I heard about this too, so you just buy this stuff (wax) from any car shop and then just polish and wax with a cloth at home on top of the headlights without taking them off?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
