Am still keen to look @ GTR rims...just need some 5 stud rotors and calipers and i can consider it.
Just got to worry about the cash layout, getting the car drivable, before considering how it looks!
But as Blitz said, will be sticking with the 4 stud for a bit.....more interested in throwing the money towards other performance parts atm.
Ando
Ando
ha ha! if you got 33 gtr rims, when i got my arse into gear (or got some money :O) we could be twins :O with wsx kits :) he he he!
