I was thinking, would it be worth the effort of insulating the air conditioning lines, especially the ones that go along near the exhaust area? The main reason I'm thinking about it is I have a whole lot of thermal wrap which I pulled off my rusting dump pipe recently, and it's kind of in bits and pieces and not really useable for much else. I was thinking I might salvage what I can and try wrapping it around some of the aircon lines. Anywhere else I should try wrapping it?
https://www.sau.com.au/forums/topic/111737-insulating-airconditioning-lines/
My brothers R31 has silver, alfoil type sleeve over the lines that run up past the exhaust manifold.
Don't think it would be standard factory fitment, but it may have been, anyone clarify?
Protecting them from the radiant heat from the exhaust manifold is a worthwhile proposition.
Its not going to effect ac performance a great deal, but it will extend the physical life of the rubber hoses.
I've got that foil stuff in that area too, but I think there are lines which run past there forwards. There's probably not a whole lot of difference insulation can make while the car is moving, but it might make the air a little cooler when idling in summer traffic. I guess I'll just try it and see, I think the only other use for this stuffed heatwrap is to throw it out.
I did it on my last car (Berlina V8). I didn't notice any difference in the A/C efficiency, but I don't see why it can't help? My lines were thin metal pipes that went from the gas cylinder to the A/C compressor and condenser.
Heck... why not!? =-]
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
