post-23260-1143943313.jpgR32 GTST,89
METTALIC BLACK
5 SPEED
FROUNTMOUNT BY ASE
BN BODYKIT
WORK VS 18INCH RIMS
107,000KMS
BODY AND ITEIOR EXCELLENT
CD,AIR,POWER
FINE EXAMPLE OF A WELL LOOKED AFTER R32
$16,000 0.N.0
PHONE 0417822386 OR EMAIL [email protected] for details
https://www.sau.com.au/forums/topic/112009-r32gtst/
