i have my r33 gtst for sale
i have the following mods that i can remember
Exterior
wide flared front guards (fitted in the next week or so)
rear gtr guards 20mm wider than standard (fitted in the next week or so)
18" wheels
400r body kit
Gtr wing
Interior
red sass fixed back driver seat
red sass recliable passanger seat
In cabin Cusco strut brace
Autotecnia race steering wheel
Auto meter and speco gauges built in dash
apexi el boost gauge custom made piller
Nismo gear knob
Ice
Clarion head unit
Clarion front and rear splits
Custom sub enclosure
12" 1500w kenwood sub
5 ch amp
Engine
rb25det
20thou over
Head port and polish 30% more flow
arp rod bolts
Shot penned rods linished resized
ACL race bearings
Venoila forged pistons
High mount manifold
50mm waste gate with screamer pipe
brand new garrett gt 35/40 with .82 rear housing
Hks mushroom air pod
hks turbo timer
denso 800cc inj
Bosch 044 motor sport fuel pump
1.5lt stainless steel surge tank
Standard r33 gtst lift pump
Hks 3" zaughst
Custom made dump and front pipe
Split fire coil pack
Fully balanced crank, flywheel, clutch everything
Xtreame button clutch
Apexi power fc and hand controller
apexi avcr
custom made oil catch can
Teflon stainless steel braided water line
Teflon stainless steel braided oil line
Custom made turbo blanket
Stronger valve springs
Reseated and reseated valves
valve guides
plenum
600*300*100 fmic
greddy type r bov
Mech 2 way diff fitted
cutom made turbo blanket
polished turbo housing
z32 afm
oil relocation kit n b & m oil cooler with thermostat
thermo fan
kill switch
This motor has being blue printed balanced and is yet to have its tune will make 330rwkw with ease
More specs up soon as any questions as I will have forgotten something for sure
im chasing 26,000 ]firmwill trade for some thing cheaper with cash my way
it currently have a set of lovells lowered springs
heaps of spares
will throw in brand new semi slicks with rims never used for the right buyer
have all recipts for motor n drive line adds up over 25k
reason for sale
im goin into a bussiness venture need the money
Edited by teazn_r33
https://www.sau.com.au/forums/topic/112356-modded-r33-gtst-300-rwkw/
  • Replies 41
  • 7 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
