Hey guys, I am new to the Gold Coast area and as a result know absolutely nobody in the area. Just come down from Townsville at beginning of year! Am keen to meet some fellow skyline owners and get out and have cruise or something. Car sitting in shed and has not had any fun for a while. If anyone interested lets get out and about. Probably seems a bit desperate but i want to get me car out and enjoy the common interest of skylines with others!
I have a R33 GTS sedan, has been modded extensively with Series II RB25 DET (Bored to 2.6 litres with forged internals), Manual, Kazz Mech LSD 4.11 diff ratio, Plenum Modded, IC, Wolf3d V4 plus, etc etc. Car puts out 220KW@the wheels. Look forward to hearing back from yas!!!
https://www.sau.com.au/forums/topic/112382-new-to-gold-coast/
Hey no worries, here is some pics of the rocket. It probably seems like a bit of a sleeper, but then again cops never worried me before. All work on this car has been done by myself, even the engine rebuild (except balancing and machining work). Only been to shop for dyno tuning
post-26828-1144219129.jpgpost-26828-1144219355.jpgpost-26828-1144219513.jpgpost-26828-1144219727.jpg
Edited by 12DFY
Very nice mate. Will have to keep and eye out for it or better still come along to a cruise..
Cheers
Chris
Thanks. Yeah will have to come along for a cruise. Will be a good way to meet some people. How often do you guys go for cruise? Next couple of weekends are out but after that will be keen as mustard!!!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
