All,
Hoping the forum can help me as I've exhausted many avenues?
Have a issue with my R33 GTST no delivering under boost, any boost that is.
Symptoms are:
-Very noisy when boost pressure becomes positive (induction type noise)
-No power (timing retarded)
-Struggles under load
-Have measured AFR while on dyno and mix drops to 10:1 before the fuel cut kicks in (boot pressure variable)
-Very poor fuel economy
Work done so far:
-Replace faulty coil packs with Spitfire coil pack
-Replaced air filter
-Cleaned AFM (though should be self cleaning)
-Replaced various vacuum hoses
-Wound down the aftermarket BOV to minimum
-Ran fuel injector cleaner
-Had mechnaical inspection
Any ideas much appreciated, thanks.
https://www.sau.com.au/forums/topic/113164-boost-problem/
could be a fault with the turbocharger or could be stock ecu taking out timing and dumping in stacks of fuel from picking up detonation. drop the exhaust and see if the exhaust wheel is ok. could try factory ecu reset.
https://www.sau.com.au/forums/topic/113164-boost-problem/#findComment-2087093
Thanks for that.
I reset the ECU occasionally, have even done an ECU diag and get the all clear "55".
I'll have a poke at the exhaust on the weekend, have always wondered about the condition.
If the ECU is overcompensating for something, which sensor could be faulty and not register in the ECU diag?
The condition is intermittent, though strongly biased towards the bad. On nice cold mornings the 'behaves' itself, tourqey and responsive when the boost is wound down to factory. But crack it open a little and problem repeats. Anything load related sets it off, passengers, A/C, warm/hot day.
This is why I suspected the ext. BOV? Tightening it only gave me temporary relief.
A number of forum article say this is typical of BOV faults, something amount accounting for the air flow, but I don't understand what sensor is causing the overcompensation?
Frustrated....
https://www.sau.com.au/forums/topic/113164-boost-problem/#findComment-2087156
the factory ecu has excess airflow protection, when you turn the boost up you will hit the limit. it will retard itself and dump fuel to protect itself. keep below about 10psi. no sensors will be faulty, it could just be the knock sensor picking up lots of detonation, so the ecu retards and dumps fuel (again to protect itself)
it sounds like your hitting excess airflow protection
https://www.sau.com.au/forums/topic/113164-boost-problem/#findComment-2087172
What I don't understand is this fuel cut will occur at or below stock levels (~2-5 psi).
I used to run 12psi quite comfortable until the last winter trasnitioned into summer and the boost limit slowly dropped, but again recovered on cold days.
What other symtoms would a worn turbine exhibit?
many thanks
https://www.sau.com.au/forums/topic/113164-boost-problem/#findComment-2087341
hmmm, none of that. All audible noises are ok except when boost is positive, becomes loud as if boost was bleeding from the manifold. Also plenty of boost comes on quick, just doesn't translate to power but!?!?!
Is the turbine still worth a look?
You mentioned detonation before, isn't that rather nasty to happen? Could my knock sensor be faulty?
Can't help but feel there is a simple yet elusive answer. There is nothing obviously broken, as revealed by inspection.
Thanks again for the suggestions.
https://www.sau.com.au/forums/topic/113164-boost-problem/#findComment-2087443
  • 4 weeks later...
Okay, finally got to the inspection, and the turbine wheel spins freely. I tested and cleaned the O2 sensor at the same time. I manually pushed the swing valve actuater rod to check for resistance or play, I couldn't detect any, though an air gun would be better.
A test run proved interesting. Though 'nothing' had changed, and the O2 sensor would not affect performance under load, the behaviour was different. I'm getting the same retarded response under boost, but now I don't get the fuel cut anymore, it hits the factory boost limit (~7psi) and stays there.
According to the Nissan workshop manual says a faulty swing valve will be a 'high cause' or 'no power/accleleration'. There is no suggestion on how to fix it, except that the vacuum hose might have a leek.
https://www.sau.com.au/forums/topic/113164-boost-problem/#findComment-2156152
  • 7 months later...
Have discovered the fault to be a crack in a hose, that connected the intercooler to the inlet manifold. However given is was right on the frame, the crack was not visible until the intercooler was dismantled from the housing. Very simple in the end, and all the symptoms make sense in hindsight.
Thanks again everyone.
https://www.sau.com.au/forums/topic/113164-boost-problem/#findComment-2797378
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
