Battle Field 1942
Guest neoGT-25
its got to be the best WWII fps i have ever played :(
(yes better that DOD) its just so fun!
you can use infentry, planes, tanks, ships, aircraft carriers, submerines, jeeps, APC's, AA guns and all different wepons :)
the game is SOOOOOOOOO GOOD!
i have it and the expansion... everyone should invest in a copy
bad things: it's a very hungry program... you need lots of Memory to run it and a good 3D card
https://www.sau.com.au/forums/topic/11326-battle-field-1942/
hey there
guys have you got any good aus servers for MOH and Battlefield 1942 if so let me know
got both those games and have no server to play online with
1942 rocks though as a FPS for that fact that you can get into any car or truck gun whatever and just kill everything if MOH was like that then it would be a thousand times better than 1942
https://www.sau.com.au/forums/topic/11326-battle-field-1942/#findComment-197979
Yeah I use all seeing eye...a free game finding client..its got heaps of servers for Aus battlefield, and you can restrict the list like aus servers, less than 100 ping, not full etc so it pretty usefull. It also auto updates itself with new games. I use it for Q3A as well. Damn fine proggie
get it from
http://www.udpsoft.com/eye/
https://www.sau.com.au/forums/topic/11326-battle-field-1942/#findComment-238328
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
