hey pplz jus thought i'd share my new pride and joy! previously had a r33 s2 gts-t but now its a r32 GTR!. after looking for quite sometime being carless got hooked up from a SAU member! (japp_imports give him a pm if ur looking for sum cars!!)
anyways heres the details
model: '90 nissan skyline R32 GTR
kms: 75,000
mods: apexi pfc, hks super dragger, apexi power intake filters, splitfire coilpacks & gab coilovers
all in all very happy with my purchase! gta do sum more power making tho'.
heres the pic :P
https://www.sau.com.au/forums/topic/113545-my-new-car/
Awesome man, wondered when you were buying one..
btw, car looks very clean.. How does she go?? given it some yet??
Love those p1s.. Keen on sellin it, however i dont think those offsets will fit on mine..
anywyas Speak to ya on msn about it...
Edited by siddr20
https://www.sau.com.au/forums/topic/113545-my-new-car/#findComment-2093704
hehe yeah the p1's are only 16's i think ill be keepin em so i can pay for better quality tyres then jus cheap big size! hehe..
goes pretty well jus need to finish off the exhuast and boost her up abit!
differnce between the gts-t, it seems the GTR is more fragile, however thtas probaly because im taking the up most care and always thinking sumfin is wrong as it is an older car. i will be takin it for a full service soon and after that my opinion shud change! im pretty sure its mechanically A1 i jus need it checked up to make sure b4 i get more parts :bomb_ie:
https://www.sau.com.au/forums/topic/113545-my-new-car/#findComment-2094064
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
