Hey all,
Are you looking for a Black metallic R32 Gts-t in excellent condition?
At only $7,000K this R32 features:
  • Make: Nissan
  • Model: Skyline
  • Series: R32 GTS-t Type-M
  • Year: 1990
  • Engine 2.0ltr Turbo (RB20det)
  • Colour: Black (732)
  • Body type: Coupe
  • Transmission: Auto
  • Kms 74,050 (With service books)
  • Price $7,500 AS IS
  • Blitz auto turbo timer
  • HKS boost gauge
  • RS-R cat back exhaust
  • Apexi Air pod
  • Lowered Suspension
  • R33 GTS-T alloy wheels
  • Roadworthy tires
  • Drop down Type M front spoiler
  • Orange front indicators
  • Recent Full Service
  • Will full Service history books
  • Immaculate trim
  • Good paint job
  • No damage or rust in the under body
  • Excellent overall vehicle
(Car is semi compliance, only needing side intrusion bars and engineers report)
Additional images are available on request
all paper work is also supplied for the car if you wish to arrange/complete the compliance yourself
other images available on request
Regards
Gareth
Edited by gaffa
https://www.sau.com.au/forums/topic/114051-r32-gts-t-type-m-coupe/
  • 2 months later...
  • 2 months later...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
