Original Eboost for sale, Given to me as a birthday present, and has been sitting in a drawer for a while, unused, unopend in box. Still even has the sticker etc...
This is basically brand new, Im open to offers, either post in the thread or PM me.
- oh reason for selling , it was going to be fitted to my car, but i am fussy and have my eyes on the new eboost 2 sleeper edition. :D
Hi ppl , the unit looks IDENTICAL to this pic.. in immaculate condition. 66mm , fits any 2 5/8 inch gauge pod or pillar mounting system.
see link below for more details on the unit
http://purchasenet.com.au/shopping/product...a33f7a290bd5f06
have had a serious offer , but was just a little lower than i had hoped... so keep em coming!
also spread the news,if a friend or someone you know may be in the market for one.
:D
Edited by dark_rb30
Im sorry but ive only found both the eboost and the eboost 2 for $750 to $900 so i dont know where u are finding the eboost 2's for $500
Free bump
:D
yeh damn, can you get me an eboost 2 for $500 !! tell me where! :angry:
