my 4WD light comes on every now and then when i start the car, although all i have to do is turn it off then on again and it goes away. By the way, the car loves to get sideways when the light is on... good old RWD :whistling::):P
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111319
yeah ive tryed that and it stays on all the time. wen it hits boost it really goes sideways
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111333
Doesnt say what the abnormality is - it's just a warning. As per Andy's post it obviously stops working otherwise he wouldnt get it so easily sideways in the dirt.
As the car is constant AWD there is no switch to turn it off or on. except for the synxchro (S) button which I believe acts more like a central diff lock. Which is why the steering gets heavy on full lock when synchro is activated.
Not that I know any of this by expereienxce as mine is 2WD only.
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111376
abnormality? like...?
not operating correctly, low attessa fluid maybe (in the boot) ??? dodgy wiring, stuffed attessa pump, or anything related with the attessa stuff, try accessing the attessa ecu in the boot as per another post i showed pics of where its located and read the diagnostic light sequence and check it up on the workshop manual for what is the problem.
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111380
i have mine come on every now and then, when it does, i just turn the car off and on.
I also had it come on once because i didnt put the plug back right into the ecu and one end was being held up.
also, i got it when i disconnected the vac line on the bov for some flutter, car stalled and then the 4wd light would come on every now and then along with the car driving like poo. It went away after a while, guess the ECU taught itself.
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111459
Who said anything about being in the dirt? :):(:bunny:
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111701
Please dont ask for manuals.
Other than that, I dont have a 4WD light, mines a HICAS light, same thing as I have a 260RS dash, and mine never comes on, only when the key is in the ON position but not actually started the car....?
But all that said, Brad is spot on, check fluid levels and/or attessa system!
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2117873
4wd light on all the time = not bled or no fluid...if it goes sideways, its prolly not working, check the resovoiur in the boot and see if both the top and bottom tank is full? and maybe bleed the system too...might fix ur problem...but my light stayed on when i put my engine back in last week until i bled the system out :D
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2117928
the tank is full, but ive been told that theres a earth wire in the engine bay for the atessa system, so they might of removed it so im goin on a hunt when it stops raining over here lol
ska - sweet as dude i wont
Edited by gzzmos
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2118106
WHAT DO YOU MEAN BY DONT ASK FOR MANUALS ????????????????????????????I DONT GET YOU GUYS .ITS OK FOR FUNKY TO SELL EM SORTA BUT NOBODY ELSE IS ALOWD TO SHARE .......
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2118116
There is a $189 / 491 page R33 Service Manual, I think thats the one they mean. There 'was' once a link to it for a downloadable PDF file of it, but thats been shutdown. Im pretty sure JPNZ own the rights to this translated manual, and therefore it breaches copyright if it is 'exchanged' between ppl wiothout $$ rights going to JPNZ.
I dont know how Funky has gotten around all that, maybe becasue his manuals are in Japanese writting and the local Japanese copyright may not be applicable in Australia, whereas JPNZ is a New Zealand company who translated this Japanese manual, and being based in NZ therefore AUS laws apply.
Hope that helps! I was lucky enough to come across the service manual in pdf format (via GOOGLE, hahahaha) just before the webpage was shutdown. I saved it to disk and have not reproduced it in any way shape or form. Lately I have been asked a lot if I can forward this pdf.file onto ppl.........
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2118157
My manual came with the car - its a JPNZ one, but only 258 pages. An abbreviated version like the type you normally would get in any jap car that tells you every useless bit of info about how to turn lights on and off and how to drive the car up and down hills. But never contains anything mildly important if you want to fix something - standard reply is, "if in need of servicing please refer to your nearest Nissan dealer."
All that aside, it did have extra info on the 4WD light dilema. And I qoute:
The 4WD light will illuminate when the ignition is turned ON and it will turn off when the engine is running.
When the 4WD warning lights shows or will not illuminate when the ignition is ON, have your vehicle checked by your Nissan dealer as soon as possible (told you it was helpful)
If the warning light flashes check that all tyres are the same size and brand (This includes air pressure) If the light continues to flash, then (you guessed it) have it checked by your Nissan....
If the light turns on when driving, the ATTESA system will cease functioning but normal driving will be possible.
The 2nd last point makes sense - if the tyres are rotating at different speeds then the ATTESA isnt going to engage because it will be fighting against itself like trying to engage two gears at once, so it will opt out and not engage at all, hence the warning light.
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2119084
  • 16 years later...
So light could be on because of uneven tyre pressure? Would that apply to just the rear tyres though.
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-7968167
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
