Ok,
Lets not start any bitch fight here, I am just wanting to get an idea of a tuner to goto.
I have got no time to muck around with my car before the Drag wars to get it sorted, therfore I need to get the S-AFC done on a dyno.
I was wondering about the best place to take the car for a tuner who can set the adjustments quickly and correctly and hence saves me some $. Needs to accept credit card payment too.
It looks like people will finally get to see how much power my car doesn't make to achieve a 13.4.:)
https://www.sau.com.au/forums/topic/11477-need-dyno-tune-for-s-afc-where/
INASNT,
That's right I don't 'need' a dyno to tune my car but, I do need alot of time and I don't have any before the trip and then very little time when I get back.
Besides, from the sounds of things Steve knows his stuff and He'll probably get more than I ever would have.
Steve,
I was going to get some ngk 7's since I expect the rev range has lifted since the cam gear etc has gone in. My old rule of thumb was 6's for 6000rpm 7's for 7000rpm 8's for 8k and so on. Does this sound like a plan mate?
I think people are expecting to see you have 250+hp dave, to justify your runs. What they dont realise is the mods, like the lightweght flywheel, wont show an HP gain. Dave might only pull 220hp with 10psi, yet his car has run quick times, just another reason why you cant use a dyno to gauge how fast a car is. Remember aswell, dave's had a fair wack of experience in racing cars, so he probably drives a lot better than most of us.
You know I just had another play with the S-afc and I thought 'yay - I've got it all sorted' cause I had a whole day without fuss and ping and a little bit more timing.
Then when I least expect it..... ping and knock. I have the tune sailing too close to the wind I guess but, boy does it go now!
I have added a little fuel in the correction map up top +3. I have kept a fair bit of timing to boot. I am tempted to go a colder plug and see if I can keep the advance but if what steve says about the 6ES is right then there is probably another way around it.
I have my trusty Autolite racing plugs that are a range cooler (7 equivalents) these I had with a gap of 1.1mm before the other bits went in and although a tad cold for the rich stock ecu maps they ran a little better than the 6ES up top all the same (then fouled doh! I expected that). I'll have to clean them up again. Anyone else tried the Autolites?
Steve,
Do you reckon there is more power to be had if I retard the timing (its about 5degrees past the last mark at idle) and then do a leaner correction using the 6ES plugs?
Also if you would like me too I can bring the car in sometime on the 14th of march.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
