parts in melbourne forest hill
0401 842 644
issotta real leather stearing wheel. $250
momo peddals $60
cadance amp 45x4rms $200
kicker 12" comp vr $150
r33 lsd diff $250
pics linked below
http://www.skylinesaustralia.com/forums/in...howtopic=108118
Edited by mook1
https://www.sau.com.au/forums/topic/114785-more-aftermarket-parts/
0401 842 644
Autometer 2" Ultra light Pro Comp Air/Fuel Ratio Gauge with Carbon fibre Mounting Cup, new $180
r34 C's shortshift kit $250
momo peddals $60
momo knob shifter $60
apexi I safc $ 220
alpine 9831 headunit $350
trust vspl intercooler kit for r33.. needs new end tank welded on.. 300
r33 lsd diff $250
pics linked below
hi ,can you post pic of momo knob shifter?
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
