Heya guys,
Got another one for you fellow out there.
I have just recently noticed that they is clutch fluid leaking in the footwell of my cabin in my 32 GTS-t.
I've spoken to a mate and her reckons that I need to buy a slave cylinder reconditionin kit to get the seal that is busted and causing the leak.
I want to fix it up fairly soon but I reckon that buying a $150.00 kit for just a rubber seal is a little waste o money.
Has anyone else had the same problem? Andi fi so, how did you go about fixing it up??
Thanks heaps guys! (Love this board!!!)
NT
https://www.sau.com.au/forums/topic/114787-clutch-fluid-leak-in-cabin/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
