Item: R33 Nissan Skyline
Reason for Selling: want a 4 door 4 wheel drive. possibly swop for bug eye wrx
Price and Payment Conditions: $22500
Extra Info: Late 1993 Nissan Skyline R33 GTST (series 1)
This is a reliable high spec car going for a very reasonable price. No expense spared in the modification process and always used top tuner and mechanic (Chapman & Chapman Automotive)
Excellent performance but still a daily driver
Power: 350HP ATW
Miliage: 85 000 kms
Engine Modifications:
GCG Hi flow Turbo
Tomei 550cc Injectors
Blitz Front Mount Intercooler (plumbs back to standard holes on passenger side)
Os Giken Exhaust Cam Pulley
Turbosmart type 2 BOV
3” turbo to CAT
3.5” CAT back exhaust
3” Hi flow CAT
HKS mushroom filter (with spare insert)
Z32 AFM
Bosche 979 fuel pump
Bosche fuel damper
Sard Fuel pressure regulator
Carbon Fibre cold air intake box, with standard snorkel fitment
19 row oil cooler
Oil filter relocation kit
Electronics:
Apexi Power FC, with hand controller
Apexi AVCR boost controller
Auto meter Shift light + Tacho
Suspension and Brakes:
Tanabe coilovers
Front adjustable castor rods
Rear Whiteline camber kit
Whiteline differential cradle bushes (pineapples)
DBA 4000 Rotors with Ferrodo race spec pads
Front and rear strut braces
Exterior:
Carbon Fibre GT wing (conforms to QLD road rules and is legal)
Flush boot “drift” wing
M spec front bar, with intercooler space cut out
400r Side skirts
Black Bonnet
Other:
Radiator air guide
Skyline floor mats
Immaculate interior
17” wheels 9” wide rears
255 Nankang’s on rear
235 Toyo’s on front
Mines 300kmph Speedo
This skyline has well over $12,000.00 worth of modification done to it and all has been carried out by Chapman and Chapman automotive.
Serviced every 5000kms and always used Motul 8100 oil.
Timing belt was changed when I got the cam pulley installed (3000kms ago)
Gearbox oil was changed to redline shockproof as soon as I purchased the car (march 2004)
Contact Details: neil smith 0431912336 [email protected]
i am in no rush to sell this, its worth heaps more then the asking price
will swop for bug eye WRX
https://www.sau.com.au/forums/topic/115120-350hp-r33-nissan-skyline/
I will gladly vouch for this car. The sound of the turbo at peak boost is simply amazing.
Very reliable as well because its being looked after & tuned by Chapman & Chapman.
:ban:
sedan headlights you mean?
no acco history, the previous owner changed them as the stock lights plastic/glass was all blurry and damaged.
i got the car cheacked out when i bought it from him and there were no signs of any accident
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
