Item: 1987 HR31 Skyline GTS Coupe
Website: Pic's here
Item Condition: Great for age, interior immaculate
Reason for Selling: Time to move on
Price and Payment Conditions: 11,500 with coilovers or 10,500 with standard struts/springs with brand new kyb shocks (never used)
Extra Info: Well mantained by fussy owner and all modifications were done by me, first owner in Australia, 4.5 grade at auction in Japan. The car had 37,000k's when purchased and now is up to 63,000k's in the last 2 1/2 years I've owned it. The car is always garaged and is only a weekend cruiser as I don't need it for work.
Mods are: Viper alarm with remote start, RB25 T3 turbo, GTS-R Strut brace, JIC Magic coilovers (rare), genuine hybrid FMIC, Turbosmart type 3 bov, turbosmart boost contoller (running 9 psi), K&N pod filter, turbo back 3 inch exhaust, 17 inch mags, JVC headunit with kicker speakers. Also has tinted windows which were done 2 months ago (cost $350, no cheap shit), autometer boost gauge, aftermaket steering wheel.
Contact Details: PM for more info.
Edited by HR31_RB20DET
https://www.sau.com.au/forums/topic/115498-fs-hr31-gts-coupe-qld/
  • 3 weeks later...
BUMP :O
Have just paid 12 months rego on it.
Just replaced a/c, alternator and powersteering belts, the car is serviced every 4-5000k's with Castrol Full Synthetic R.
Also the forgot to mention that the car has a custom made 2 core radiator with brand new hoses and a genuine nissan thermostat.
Just a couple more pics.
if that was in my budeget of about 8.5k, id be on a bus down there. sweet ride, mate, lot of time and effort has gone into it by the look and sound of it.
ps apologies for the pointless reply! saves you bumping it i guess...
Cheers mate :( This is how it looked when I first bought it, just to show how original it was.
Ps. I still have the hubcaps too :wave:
hmmm go the 17s... that was a good move.
how much of the engine mods did you do yourself/have done?
Well the car was 100% standard when I got it, so every mod has been done while i've owned it.
Exhaust, fmic and pipe work were fitted by Mr muffer and Hardcore respectively. The turbo, coilovers and cooling system were done by my qualified mechanic mate who knows 31's inside out (owns/built his heavily modified rb30det passage).
  • 4 weeks later...
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
