Hey peoples i am Nick. Every one probly knows my car by know ARSNIK black R32 2 door GTS4.
Any ways i was wondering if some one had a original turbo off a gtst be it r33 or r32 as i have blown my turbo and need one just to get it back on the road and goin again can't be bothered buying a run around and saving the cash for a better one yet.
Cheers Arsnik
https://www.sau.com.au/forums/topic/115822-new-2-this-forum/
Cheers Arsnik
26motorsport has an r32 one.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
