OK, there's "1" other shirt that I'll part with only because it's more of a Large that an X-Large ( tagged as XL ) and might shrink a bit in the dryer and then won't fit me :O
It's also brand spanking new & top quality. I'm asking for $30 pickup or $35 delivered.
First pic: Front
Second pic: Back
https://www.sau.com.au/forums/topic/116129-sold/#findComment-2153053
This particular shirt is sort of half way between XL & L but I "always" put all my shirts in the dryer which will shrink any cotton shirt over time so I'm 99% sure if you put this one in the dryer after each wash it'll shrink. If you don't put it in the dryer it'll prol stay the size it is :O
https://www.sau.com.au/forums/topic/116129-sold/#findComment-2153240
  • 3 weeks later...
  • 3 months later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
