All
I have just purchased a set of white line springs for my R32 GTR - and I will be fitting them soon (next week or so), and I have not decided what to do with the old springs yet.
1: anyone interested in a set of std R32 GTR springs. They are std height, with about 60,000klms on them. Still work fine – but they are the STANDARD height :cheers:
2: any idea how much these things are worth ?
3: do they fit the R32 GTST - and if so are they any better than the std GTST springs ?
talk to me - should I sell them - or hide them in my shed somewhere
https://www.sau.com.au/forums/topic/116162-eoi-std-r32-gtr-spings/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
