Hi guys,
does anybody knows what tyre size for the 260rs? The factory fitted bbs wheels one. I know its 17" and i got 2 different sizes on the net.
they are 225/50/17s and 245/45/17s dont know which is which. Chasing up some prices for the tyres before the car gets here.Thanks
https://www.sau.com.au/forums/topic/116304-tyre-size/
Hi guys,
Your tyre placard (fitted when complied) should identify the correct tyre size.
The 225/50R17 and the 245/45R17 are within 5mm of each other in diameter. Also rim width may determine which tyre is a legal fitment.
Your 225's will range in price from $210 to over $400, and the 245's will range between $205 and $500.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2138536
Check with the compliance workshop that is complying your car, they will most likely know (although being a 260RS they might not) they have access to good tyre prices in most cases so that may save you a dollar or two?
Luke
Edit: How many people on here own a 260? Not sure how much help we lowly RS Four owners can be to you...
Edited by munchdesign
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2138589
if your tyre size is not the right one wouldnt it effect the accuracy of the spedo?
im trying to get a tyre from good year. The model is GSD3 f1. It a good tyre. preety cheap compared to hankook and nankang for that size.
I dont know what the comploance place will give me for the tyres. I dont want cheap and nasty one.
BTW is rating Y too much for the ccar or right on par? Thanks
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139016
Check this thread you will find some of the info you are after in here, try seaching the forum also, it seems a bit hit and miss but there is a lot of info on here already.
Cheers
Luke
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139129
The bible (TRAA) identifies 'Y' speed rating @ 300km/h.
Whoever complies the car and attaches the tyre placard have a responsibilty to ensure the correct tyre is identified with respect to rolling diameter, speed rating and load rating.
Do not be too concerned about your speed rating, the load rating is the more critical.
For example the 245/45R17 F1 GS-D3 is a 94Y. That is the tyre has a load capacity of 670kg @ a max of 300km/h.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139607
which is suited for stagea? Im more concerned about the tyre grip. Load factor ok. Im very particular with tyres i hate michilens. i dont care how good you guys sya it is. it is POS!! so either im sticking with goodyear or perrilis p6(if they stil got them)
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139689
Horses for courses. Tyres are a personal choice, some people are brand concious, others price concious. All the major manufacturers have some good tyres in their range. Your F1 GS-D3 is available in the 225/50R17,, but I have no listing for a 245/45R17. But I could recommend the 245/45R17 in the Toyo T1R for example. I personally run a Goodyear Rev Spec RS02 (235/40R18) on my Series II Stagea, and will be trialling the new Dunlop Sport Maxx on another vehicle shortly. I have had some very strong feedback from customers on this new tyre.
Wait until you know exactly what tyre size has been complied for the car and then look at the available options in that size.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2140143
if you want to keep the stock speedo accurate, use this website and find some aftermarket tyres to use with any wheels.
http://www.1010tires.com/TireSizeCalculator.asp
As far as buying tyres, just make sure you get same tyres front/rear. Replace all 4 at once. Rotate them maybe ever 6 months to a year, depending how you drive. Ive just rotated mine after 3 months and really needed to do. I do load up the front wheels quite a bit.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2140498
they sort it out themselves and fit you the bill.
they will just use the cheapest tyres that are suitable unless you say otherwise.
a
im going to ask them to save the tyres themsekves abd i will give them goodyears GSD3 for $198/tyre 245/45/17s so...his tyre is very good.
the review for t
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2144146
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
