Hi guys,
does anybody knows what tyre size for the 260rs? The factory fitted bbs wheels one. I know its 17" and i got 2 different sizes on the net.
they are 225/50/17s and 245/45/17s dont know which is which. Chasing up some prices for the tyres before the car gets here.Thanks
https://www.sau.com.au/forums/topic/116304-tyre-size/
Hi guys,
Your tyre placard (fitted when complied) should identify the correct tyre size.
The 225/50R17 and the 245/45R17 are within 5mm of each other in diameter. Also rim width may determine which tyre is a legal fitment.
Your 225's will range in price from $210 to over $400, and the 245's will range between $205 and $500.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2138536
Check with the compliance workshop that is complying your car, they will most likely know (although being a 260RS they might not) they have access to good tyre prices in most cases so that may save you a dollar or two?
Luke
Edit: How many people on here own a 260? Not sure how much help we lowly RS Four owners can be to you...
Edited by munchdesign
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2138589
if your tyre size is not the right one wouldnt it effect the accuracy of the spedo?
im trying to get a tyre from good year. The model is GSD3 f1. It a good tyre. preety cheap compared to hankook and nankang for that size.
I dont know what the comploance place will give me for the tyres. I dont want cheap and nasty one.
BTW is rating Y too much for the ccar or right on par? Thanks
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139016
Check this thread you will find some of the info you are after in here, try seaching the forum also, it seems a bit hit and miss but there is a lot of info on here already.
Cheers
Luke
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139129
The bible (TRAA) identifies 'Y' speed rating @ 300km/h.
Whoever complies the car and attaches the tyre placard have a responsibilty to ensure the correct tyre is identified with respect to rolling diameter, speed rating and load rating.
Do not be too concerned about your speed rating, the load rating is the more critical.
For example the 245/45R17 F1 GS-D3 is a 94Y. That is the tyre has a load capacity of 670kg @ a max of 300km/h.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139607
which is suited for stagea? Im more concerned about the tyre grip. Load factor ok. Im very particular with tyres i hate michilens. i dont care how good you guys sya it is. it is POS!! so either im sticking with goodyear or perrilis p6(if they stil got them)
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139689
Horses for courses. Tyres are a personal choice, some people are brand concious, others price concious. All the major manufacturers have some good tyres in their range. Your F1 GS-D3 is available in the 225/50R17,, but I have no listing for a 245/45R17. But I could recommend the 245/45R17 in the Toyo T1R for example. I personally run a Goodyear Rev Spec RS02 (235/40R18) on my Series II Stagea, and will be trialling the new Dunlop Sport Maxx on another vehicle shortly. I have had some very strong feedback from customers on this new tyre.
Wait until you know exactly what tyre size has been complied for the car and then look at the available options in that size.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2140143
if you want to keep the stock speedo accurate, use this website and find some aftermarket tyres to use with any wheels.
http://www.1010tires.com/TireSizeCalculator.asp
As far as buying tyres, just make sure you get same tyres front/rear. Replace all 4 at once. Rotate them maybe ever 6 months to a year, depending how you drive. Ive just rotated mine after 3 months and really needed to do. I do load up the front wheels quite a bit.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2140498
they sort it out themselves and fit you the bill.
they will just use the cheapest tyres that are suitable unless you say otherwise.
a
im going to ask them to save the tyres themsekves abd i will give them goodyears GSD3 for $198/tyre 245/45/17s so...his tyre is very good.
the review for t
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2144146
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
