Hi,
I am sell in for a mate a damaged RB25DET and 5 speed manual gearbox. was removed from R33 GTST series 1 with major fron end damage. Has 76,000k's on speedo.
Engine has following damage.
* Harmonic balancer broken
* Small hole in turbo front housing
* Sump small hole and dented
* Power steering and a/c pumps brackets broken off block..bolts from these brackets snapped in bolt holes
* Camshaft sensor broken
* Timing covers bent.
Asking $1000 for engine complete
Gearbox has following damage.
* Housing broken around starter motor
Asking $350..still selects gears
I have attached pictures..would be best if interested to come look at the motor/boxto get an idea..I have descibed best i can. Feel free to ask any questions.
Thanks.
https://www.sau.com.au/forums/topic/116677-damaged-rb25det-and-5-speed-gearbox/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
