17" Cheap Rubber - Only A Few Weeks Use For Compliance
Hey Guys,
In the deluge of the For Sale section, I thought I'd better check, if anyone is in or near Hobart and wants some cheap rubber. I have a set of NanKang 17" x 245, which I've only done like 3-4K on as they were just on for compliance.
After $250, as they were $120 ea.
Thx
Greebo
Offical FS post below;
Tyres
  • 1 month later...
PM sent
Mate, something is wrong with the board. Just got an email saying you pm'ed but nothing there and cant pm back (sql error..)
So you can email me direct at [email protected]
Thx
glad to put a smile on everyone's face :thumbsup:
How's the GTR coming along anyway chief???
Like all GTR's.... I'm #$%@ing broke and there is sooooo much I wanna dooo!!!!
Seriously contemplating a 3rd job....
I hope to post some more pics soon, as I spent the long weekend working out the heavy fine scratches in the paintwork. I can only assume they came from previous owner putting car thru car wash.
My mate thought I'd had the car resprayed... if thats any guide.... ;)
Also, I blew a tyre on the highway, almost nothing left of the sidewall.... :wub: OMG
But "I LOVE IT!!" and to prove a point, I had a line of guys along the side of the road, doing this :ermm: and THAT made me actually go back an hr l8tr and get more :wub:
Greebo
GTR NUT!!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
