MAZDA RX7 Series 6
Manual 13b twinturbo
MAZDA RX7 SERIES 6 TWIN TURBO UPDATED 2002, PERSONAL IMPORT SO IT WAS BROUGHT DOWN BY THE OWNER FROM JAPAN. AUSTRALIAN COMPLIANCED IN 05 2001. CAR HAS REGISTRATION HISTORY IN VICTORIA AND NSW AND CAN BE REGISTERD IN ANY STATE IN VERY GOOD CONDITION ALL AROUND, BIGGEST HEAD TURNER ALWAYS STANDS OUT IN THE CROWD. HEAPS OF MONEY SPENT ON THIS CAR, IF YOUR AFTER A RX7 WITH NO HEADACHES THIS IS THE ONE. ANY TEST OR INSPECTIONS WELCOME. ON 89,897 KS.
INTERSTATE SHIPPING CAN BE ORGANISED PLEASE CONTACT ME FOR A PRICE FOR INTERSTATE SHIPPING
ASKING $29,900 MIGHT SWAP FOR SOMTHING THAT INTERESTED ME AND IF YOU WANT TO PAY ME ONTOP
CARS LOCATED IN MELBOURNE CALL ME 0401267277 IF I DONT PICKUP SMS ME ILL CALL YOU BACK
MECHANICAL: 5SPD MANUAL, FULL REBUILT ENGINE BY PROMAZ MELBOURNE, WITH RECEIPTS SPENT $6000 ON THE REBUILT NEW HOUSINGS SEALS ROTORS GASKETS THE LOT. SEALS STILL UNDER WARRANTY. RECO TURBOS NEW BATTERY, BRAKES, 5ZIGEN 3" EXHAUST. BRAND NEW EXEDY CLUTCH.
TRAVELLED 2000 KS AFTER REBUILT BASICALLY BRAND NEW ENGINE JUST RAN IN AND SERVICED, NEVER BEEN BOOSTED AFTER REBUILD, HARDLY GETS DRIVEN
EXTERIOR: SILVER METALIC PAINT IN VERY GOOD CONDITION WAS ALWAYS GARAGED UNTIL LAST MONTH,ORIGINAL MAZDA SERIES 8 FRONT BAR BRAND NEW LIGHTS, SPOILER, 2 MONTH OLD 19" RIMS
INTERIOR: VELOUR FRONT SEATS/. MOMO SHIFTER. BOOST, OIL TEMP, AIR FUEL RATION GUAGES ON THE PILLAR POD. MP3 HEAD UNIT, 800W AMP, 12" SUB, REAR SPLITS FRONT TWEETERS ALL PIONEER,
Asking Price: PRICE HAS BEEN DROPPED $29,900
very very keen mate...
my 33 should be sold next week will have the cash then...
keep you posted
thanks
no prolem, had a deposit on it but the guy couldnt come through with the finance, so it fell through
heya me mate wants to know if ya interested in a swap for his wrx?
its a 11sec car with full forged engine/ppg straight cut gearset n lots of other bits :)
crazy economy @ 10L/100KM
Edited by shy_s6
So what exactly is doen to it to make it a 2002 update?
My 320rwkw 1996 gts-t is up for sale, and was looking at getting a rx7 in a few years time, but would also consider a swap.
This is my forsale thread http://www.skylinesaustralia.com/forums/in...howtopic=111294
Let me know if interested.
sorry after owning a gts 33 and having alot of problems i wont be looking at geting another one, but yours is neat as you shouldnt have too much problem selling it good luck
shy_s6 what year wrx is it?
im also trying to sell me jeep, dunno if your interested in a trade :( would prefer with stock rims just for a lil price drop :) also wat sus is it running looks pretty low ;) im pretty keen wouldnt mind a s6 again :P
Edited by shy_s6
commodore? i cantell you sooo many commodores, what commodore?
Holden VR Commodore
Full VY GTS Bodykit
Full respray marone color
20" ACE Rims
HSV 185i V8
Yella Terra Roller Rockers
Worked Auto trans, 2500rpm high stall & strong chev gears
Cold Air Intake
High flow air filter
extractors into twin 2.5" cats then to single 3" pipe
Full spool 4:11 Diff
King Springs ultra low's
Tinted windows
Big Sterrio
Fully re-done interior (black leather)
Alarm system etc.
i got heaps of pics if you would like to see them
Edited by teazn_r33
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
