  • Replies 75
Posted Images
Haha, might as well trade in the Stagea for this, the Chevy Kodiak:
I take your widebody and raise you
Seriously though the widebody idea is cool but the door handles on the back door of the blue stag look terrible as there is a 10cm deep tunnel you need to put your hand into to open the door. I seen pics of this type of kit with the doors open and the finish is terrible raw fibreglass everywhere
https://www.sau.com.au/forums/topic/117507-new-mags/page/4/#findComment-2187142
  • 3 months later...
hi all can anyone confirm if 18x8's with +30 offset (350Z rims) will fit with no dramas, also what offset would i be looking for if i went 18x7.5, don't tell me to go search plz im sick of reading hundreds of threads with no results, cheers
https://www.sau.com.au/forums/topic/117507-new-mags/page/4/#findComment-2490388
thanks heaps everybody i remember reading somewhere that they'd fit just wasn't sure, not really keen on them but they are cheap, the rims i want are RS-GT's from ozzy tyres but are 18x7.5 and i don't know which offset to ask for, the Z wheels definetly look nice tho.
https://www.sau.com.au/forums/topic/117507-new-mags/page/4/#findComment-2494188
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
