Sorry i couldn't seem the find the answer in the FAQ's
Basically i am after a set of Stock Stagea rims the 16x7? 40 offset rims to cover r33 gts m spec brakes
The mesh style is the type that i seen on the cars and i am wondering if there the same internally diameter dimensions as say a r33gts rim , or a r33gtr rims clearance wise .
stock r33gts rim with the r33 gts brake caliper
Thanks
Adam
Standard Stagea S1 rims won't fit on the front of R33GTST's, the spokes hit on the callipers. They fit on the rear OK though. I tried it last week for the drags, as we have the MT ET Street radials for the rear mounted on the Stagea rims.
:D cheers :P
Sydneykid
Would you say that say 5mm spacer would fix that problem ? I am using s13 struts with s14hubs and for the r32gtr rims to clear the strut i have had to machine a bolt on hub spacer of 20mm . So there is 20mm extra caliper spacing over the caliper from standard due to all the r32 rims being for a wishbone front end .
Goldzilla
Yes that is a gts wheel on a ae86 . The front brakes used to be sr20det 280mm ones for many years , but since going to very modified s13 multi link rear i have decided to convert all the brakes and stud pattern to 5x114.3 to make finding rims easier . Finding 7.5 - 8 inch rims in 30-40 offset in 4x114.3 is next to impossable now . Is basically a 86 body now there isn't much left thats not nissan or from some other make.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
