Found something I want write now. Series 2 R33, so I want to know I have a buyer now.
$8,000 for the next two days.
Have an offer already, just looking to get a little more. Will take $8,000.
  • Replies 45
I have decided I will buy that skyline on friday. If I can sell this before than, I'll let it go cheap.
If not, I'll stash it in mums spare shed and wait until someone comes up with a better offer.
taking any offers around 8k today and tomorrow.
Id so bloody buy that right now... except my car is in pieces so I cant sell it to buy that... ; ;
If your still selling this when I get mine back together, consider it sold!
One of the last price drops I feel. A few people have expressed interest now but have reasons why they can't.
$7,500 now.
I really should make that WITH OUT the microtech, with a stock diff, with a T25G and with smaller rims.
At this stage that all still comes with, but I'll start selling things off soon.
I think its relevant to mention, I now own a series 2 GTSt skyline as of today.
Jumping from one to the other, as i can do now, i can say the gazelle is alot faster, more power, heavier clutch, much stiffer suspension, certainly more of a drivers car.
hey mate just wondering if youd swap a 1990 nissan exa with 17 inch chromies exhaust bodykit not fitted colour coded plastic interior parts and more nice looking car worth about$7000 i really wanna get into drifting call me 0434895812 or leave a msg cheers
Not really after a swap because I really do actually have a Series 2 skyline now.
Also, I'd only swap a car which is easy to sell cause thats all I'd be doing and an exa isn't easy to sell for $7,000.... if it is, sell it and I'll sell you mine for $7k.
Bump.
As I have to keep saying to people, the reasons for sale are genuine. I do have a skyline now, I can show you that too if you come look at S12.
I am not into street racing so yes, the S12 is much faster, but I would prefer to own the skyline at this stage... I thought alot of people would understand that... its ok though, if you don't believe me, come for a ride in both. :laugh:
I can vouch for this car. I have been in it at eastern creek during a drift day and I can say it is a very fast and very well set up car for drift. the guy who built it knows what he is doing and the car is not dodge in the slightest.
really nice tight little car. perfect for getting into drifting...
Hey, so is this an N/A SR20 with the Turbo added on?
Yeah its a NA block, with a turbo head. So it does have the injectors of the turbo. The higher compression means you don't feel the lag very much. Please see my dyno sheet and first post if you are wonder how the car was built and with what.
cheers mate.
Yeah the guy that did all the work really knows what he is doing and only sold it to start another project, which is also coming along very well.
the car is much more similar to my old R32 GTR (which had coilovers) to drive than I would have expected. Alot quicker and better handling than my R33 GTSt.
  • 3 weeks later...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
