Due to being offered a chance of a lifetime to buy a rare and exotic muscle car I am toying with the idea to sell my GTR Running Gear which has yet to be used. Details are listed below and I ask people to please refrain from asking me to seperate any of the parts which I will not do, I want to sell the entire or I will simply keep it.
This was designed to go into an R32 GTR but most things will suit the R33/R34 GTR platform aswell.
Engine-RB26/30 Stroker
Top End
HKS 272 Step 1 Cams
HKS Cam Gears
Bronze Valve Guides
HKS Valves Spring
Match Ported
Ported to allow max power and efficency
Drain Back from rear of Head
Painted Rocker Covers
HPC Coated Inlet Plenum
Bottom End
CP Forged Pistons
Carillo H-Beam Conrods (ARP2000)
ARP Main Studs
ARP Head Studs
ACL Race Series Bearings
N1 Water Pump
N1 Oil Pump
JUN Crank Collar
O-Ringed
Welsh Plugs
Bored/Honed
Tunnel Bored
Balanced to 8500rpm
Hi-Octance Racing Sump
Rebuilt Front Diff
4WD Adapter Plate
Oil Cooler with Lines
Turbo Setup
Twin 3240 Turbos (HPC Coated)
Twin High Mount Stainless Manifold (HPC Coated)
Twin 44mm Wastegates (HPC Coated)
Twin 2.5" Stainless Dump Pipes (HPC Coated)
Braided oil/water lines
Trust 4" Twin Entry Cooler
ARC Air Box (HPC Coated)
Fuel Setup
Trust Twin Entry Fuel Rail
Sard 800cc Injectors
Sard Fuel Regualtor
Twin Bosch 044 Pumps
R33 GTR lift Pump
2.5lt Surge Tank (Dash Fittings)
Electronics
Apexi Power FC
Apexi Power FC Boost Controller
HKS DLI Ignition Amplifier
Split Fire Coils Packs
Gearbox
Nissan R33 GTR Gearbox
OS Giken 5 Speed Internals
Exedy Twin plate Clutch
Exedy Billet Flywheel
Price $25,000 FIRM. The location of these parts is in Sydney and I happy to ship interstate on behalf of the buyer at their expense.
For more info please PM or contact Nathan on 0424 519 298.
Edited by BlownNBoosted
https://www.sau.com.au/forums/topic/118987-1000hp-gtr-running-gear/
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
