G'day,
Have for sale for a Apache Warrior Clubman Go-kart, race ready (as of last year, if the rules haven't changed).
Kart comes with side, front and rear pods (brand new), a box of parts and goodies (oils etc), competition racing pipe, 15 lap old MG Red racing slicks, kart trolley, new chain, new spark plug, new brake pads and new carbie kit all installed already.
Kart was originally purchased to start getting into karting/racing but I am now starting my policing career that requires a fair bit of uni fee's which need to be paid so unlucky for me all the toys need to go ;)
Kart has been tuned by my local karting shop (Precision Motorsport at Tuggerah) and is actually pretty quick for an older model kart. I bought this kart second hand, since then prepared the kart for racing (new pipe, new chain, new carbie kit, spark plug, new pods, new slicks, new pads) but has only been used for one practice session on Newcastle track and a few trips around the block (ooops). The motor is the competition motor of Clubman series which is Yamaha KT100S engine (15hp 2 stroke). The motor is very strong making plently of power, has a strong power band which is felt when you get in the kart for the first time :D starts first time everytime even after long break in between running
I have always transported this kart in the back of my hatch pulsar as it only just fits, so it will need a trailer is these Clubman karts are fairly large.
$1200, located on the Central Coast.
Have been away for most of this year so I'm assuming the rukles have not been changed to begin racing.
Any questions/queries feel free to PM. Will get picss in the next few days and post them up.
Cheers
Edited by GTAHH
sori dude, but just a heads up...doesnt pay to assume. For competition: pipe has changed for this year so that one is illegal...also depends what conrod the motor is running,lots used to run a 'J' rod but now must be original 'S' rod....but hey great price for a recreational kart!
Cheers,
Michael
Don't we all wish, very fuel efficient, reliable, would make great daily driver, if you want to cop the fine ofcourse:) .
Will be on eBay within the week, so open to offers from fellow skyliners :ermm:
Cheers
Do you think I can register it? Would make a great daily driver... lol
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
