Hello all :ermm: wanta get rid of some gear outa my shed so...
**BRAND NEW** Tomei adjustable cam gear (intake) to suit RB26/20 - $200
** HKS Cams ** 256/264 duration, 8.8/9.0mm lift, intake/exhaust, suit R33 GTS-t - Near new $900 firm
** EXTREME Clutch ** H/D clutch & flywheel 75% wear left on it, suit R33 GTS - $250
R33 GTS-t plenum - $100
R33 GTS-t cross-over pipe & bov - $50
R33 GTS-t dump pipe - $30
R33 GTS-t standard cams - $150
GTR standard cams - $200
R33 GTS-t drivers seat -$150
R33 GTS-t lowered H/D springs(x4) - $50
R33 GTS-t Monza H/D shocks(x4) 1 shock damaged - $50
Sony 10" sub(x2), fairly old but in good working order - $50each
Sub boxes, 3 different types all to suit 10" subs - $80 each
pics will be posted soon!
most prices are negotiable so make me an offer if you’re interested in anything
You can contact me via PM
Im in Tassie also
:D
-Luke
https://www.sau.com.au/forums/topic/119122-skyline-various-parts-for-sale/
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
