im selling a RB25 ECU thats has a Link chip put into it
came out of my R33 skyline
i have been told it will only work with series 1 rb25 engines
im selling it because im upgradeing to a RB26 engine
$350 ono
any questions please ask
[email protected]
0409 589 376
https://www.sau.com.au/forums/topic/119641-nissan-rb25-ecu-chipped/
hi it will work but you will need a dyno
cheers bruno
i got a rb25det 180sx, series 1 motor, but its got fmic exahst and pod, stock turbo running 10psi.
would this ecu make it run rich?
  • 1 year later...
hey mate .. still got that ecu??
i know you got 330kw atw .. in your car .. but what is the rev limiter set to .. and speed controller what ever its called is set to .. my r33 is set for a top speed of 180 .. just need a lil bit more speed then that :(
cheers mate
  • 1 year later...
$350 ono
[email protected]
0409 589 376
You in Melbourne? I need a remapped ecu. Dont have many mods atm, just filter and a bit of boost. What were you running on your car when you made 330kw?
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
