I have a mitsubishi TD06 with internal wastegate, has a T3 flange flange. Is in very good conditon, very little shaft movement.
Turbo has a 12cm exhuast housing so good for 450-500hp, would be laggy on a RB20 but good on a RB25.
Have seen same turbo do 357rwhp on a RB20.
I dont get on here very often so either email or msg me
[email protected] or 0419943997
Im in WA, will ship at buyer's expense
Chasing $750ono
Pic's upon request.
https://www.sau.com.au/forums/topic/119769-mitsy-td06/
hey bud
how much boost were you running? Do you know the age of the turbo? Were you the first owner or did you buy it 2nd hand, got any pics? what power were you making on your application, did it blow any smoke? Why the sale?
cheers
Nathan
edit: im guess this is a td06 20g?
https://www.sau.com.au/forums/topic/119769-mitsy-td06/#findComment-2207738
hey bud
cheers
Nathan
have replied email
https://www.sau.com.au/forums/topic/119769-mitsy-td06/#findComment-2208104
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
