Hello, I just registered.
Nice Forum, Clean look
So this is my first Post, I am owner of a VW Golf 3 TDI Station Wagon, and a Supra TT 6 Speed.
I live in Austria, so we drive on the other side of the street, so we don't have Skylines over here, and the
couple of Cars that made it over here sell for way to much.
What I want to know is wich R34 Skyline is the best base to Convert it to GTR? I would like to have the AWD too.
Interior does not matter to me.
Please be kind, I am just getting started with the Skyline Topic.
Best Regards
Ingo
PS: If sombody wants to know something about Supra's maybe I can help out.
https://www.sau.com.au/forums/topic/120058-conversion-question/
Thanks for your quick reply
The reason is that I dont want to pay that much, also I dont need the suspension and the brakes, I can use Aftermarket Parts instead.
But I want the engine, drivetrain and AWD of the GTR.
Engine and Gearbox are not so hard o get, but I want to know wich car would be the best to start? What Parts do I need to change?
It will probably cost you very close to the same as buying a real GT-R, and once you were finished, you'd wish that you'd have gone and bought the real thing instead.
Edited by Bluprint
The price on any GTR R32-R33-R34, is going to drop. Very few cars can be seen as an investment, and the Nissan GTR aint one of them.
The GTR's that will do best on re-sale will be the rarer spin-offs. The NUR-SPEC R34 GTR should hold its value more so than a stock R34 GTR.
The other problem is the new Nissan GTR is due out in the next year or so, this will hurt re-sale even more.
Dont buy and own and run a GTR unless your willing to spend and lose a lot of your money, they aint that kinda car.
That is really nice because I dont care about the value, only if I have to pay it.
Thank you very much, I will wait until the next GTR is released and buy a R34 GTR then.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
