OK,
After having my 9th knee surgery I figure I gotta look after my legs a bit better, being 6ft8 and driving a Stagea is quite cramped for leg room, comfort etc.
I need the drivers seat rails extended in length so that I can drive it with the seat extended right back to the rear seats, and my wife can drive it with the seat at the closet position to the controls. I also figure it should have an engineers certificate in case of a accident & insurance claim.
Wouldnt mind a nice comfy Recaro but I can add that later. Where should I be going to have this done? Im thinking Willshere Motor Trimmers but does anyone have any suggestions?
Brendan
https://www.sau.com.au/forums/topic/120103-seat-rails-extended/
Alternatively, what are the dangers of taking out my seat rail, and redrilling holes further backwards, and bolting the seat back into these new holes, so it sits further back?
Is that legal?
Again, where can I get this done? I cant kneel anymore so therefore I cant do it myself.
Edited by Tangles
your best bet is to ring around some places. whillshere are the most $$ place in adelaide.... got to them and expect to pay at least 500$ per seat.... . most car seats usually have a rail that attaches to the floor and a second rail that slides in this and is attached to the seat... what you may be able to do is mount the rail attached to the seat further forward - which will ofset the seat further backwards in relation to its original position... however this will mean that you will lose x cm from the closest point you can now put your seat to the steering wheel. mounting seats is a right pain in the arse... i didi it in my alfa with some recaro style ones and eneded out getting a friend to help me do it (he has a whole heap of metal working equip) the thing is to keep it legal allways try and use the factory mounts and brackets - just modify them and make sure you use material that is stronger than the factory metal... perhaps if you remove thepassenger seat, take the rails of and have a think about it you might find a reasonable and easy solution... if you take the passenger one out post some pics and i might be able to suggest something.good luck
Brendan as for the legality of doin it............ahhhhh i wouldn't worry about it, because of some other stuff on your car. Even if you were to get defected for other things than that and had to go to regency you would put the rails back in! And besides don't think a cop would realise unless you were sitting in the back seat(and in your case you prob could)
Cheers for the advice. Thats a good idea about rebolting to the seat itself. Extra IQ points to you MrAnderson! If not thru Willshere who else? ta for your thoughts.............
With legality, more worried about an accident where the seat 'possibly' goes thru the front window (lol). Questions would then be asked - how was the seat bolted in? Id reply (from my grave) "I used Mechano/lego nuts and bolts" :(
Yeah, more worried about insurance implications in case of an accident, couldnt care less about defect etc. I reckon itd almost be impossible to be defected for my seat if it was extended backwards as such.
well i wouldnt worry too much about the seat flying away :wave: the idea of using the orignial rial and floor mounting points is that they are how the car was designed from factory and thus the safest... if you look at most seat rails the steel used for them is quite thin - it gets its strength from being moulded into a C shape or similair. if your not keen on takling it yourself your best bet would be to ring around some race car prep and engineering places - as opposed to auto trimmers... some may do it but you will prob find more willingness to help and less $ from a genuine engineering or car prep place..
heres the details for a place i know of (they usually work on euro stuff but i understand they do everything)
Start (Sirius Track And Road Technology) LLoyd Clonan
Specialising in Race Car preparation and development and project completion
Address: U3/14 Barndioota Road, Salisbury Plain, South Australia
Fax: +618 (or 08) 8283 4502
Phone: +618 (or 08) 8283 1970
Email: [email protected]
give em a ring - perhaps they can help or point you in the right direction
Thanks Lucas, yeah sounds like thats probably the go. I guess I'll contact some engineering firms down south and see what can be done.
If I could kneel then Id take out the drivers seat and start measurements, etc, and go from there. As it is thats impossible for me, so I'll measure up my wifes seating position vs the very forward position, get the difference in length, and then go to an engineering firm and say "alter either the seat bolts or the seat rail by xcm"
Ta for your valuable input. Need some $$ now. LOL
Edited by Tangles
seeing 'Marvn' tomorrow :D so we'll see what we can work out.......
Fact is, I dont fit comfortably in the standard local fare (falcodores etc), so I need to safely modify one small section of the seat rail to suit me.
Id argue it in court if necessary (god forbid!) that whatever it is that I end up getting done to extend my drivers seat rail lenght is a completley safe modification, to suit me.
Edited by Tangles
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
