as you can see 300rwkw can be easily made on stock commondoor parts.
just need a good builder to check the basics and away you go, thats the point of the rb30det. drop in stock parts and rape it till it goes bang.
guys have used 200,000k bottom ends and have still been in near perfect condition
Then there's Bu5ters 8500rpm RB30DET monster. :)
3lit3_32,
You missed one VERY important part of a high rpm build. The oil pump drive crank collar.
The RB30 requires a fluid balancer (ati) for it to be reliable @ 7000-7500rpm+.
I was suprised how nice an RB30DET GT35R .82 was to drive. It made boost from as low as 2000rpm and hit hard around 3500rpm and this was on a fairly low comp rb30det as it was running stock rb30 n/a pistons and a 1.6mm head gasket. Off the top of my head a shade under 8:1.
A GT35R .82 on an RB25DET... I really wouldn't like to drive it lag isn't my thing.
For a daily driver, I wouldn't run larger than a gt3040 on the rb25. I tend to trust mr Nismoids spool/lag figures.. GT3040 .82 on rb25 I believe it got up and started to move at around 4000rpm.
Now drop the gt35r on the rb25 and your easily looking at another 500-600rpm.
Go 3ltr if you are hell bent on using a GT35 IMO.
700hp turbos are just not the RB25 cup of tea
calaisturbo.com
reults speak over there with the guys using GT35's on the 3ltrs with amazing response.
As for 450rwkw from a GT35... thats interesting. You'd be leaning on that ever so hard, and with race fuel to boot to make that sorta power
My Rb30DET has run 784rwp (without NOS) and a 9.3 sec quarter. Its rated to handle 1200+hp.
RB30 Bottom end
Cryoed crank
Arp rod bolts and head studs
Argo rods
Custom JE Pistons with with 22mm Gudgeon pins and lowered ring lands
3/4 grout filled block
copper head gasket
RB26 Head
Heavily ported by headsense
Heavy duty valve springs
HKS Cams
(i keep most of this info quiet)
Inlet plenum
105mm throttle body
Direct port NOS system (including soleniods and 10 pound bottle)
Rochester 1240cc injectors
Additional injector rail
Custom fuel rail
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
