A full, comprehensive product containing everything you need to install and use this Honda 2000 style Engine Start button.
Included in the kit;
Full, step-by-step instructions
The Honda S2000 style Engine Start button
A very heavy duty 40Amp relay so the kit can power up your starter-motor solenoid
A professionally produced wiring loom with generous amounts of heavy duty cable
Connectors to connect the kit to the vehicle wiring
Cable ties to keep the wiring nice and tidy
It will work on all cars no matter what alarm, immobiliser or key it uses
Completely new
$90
https://www.sau.com.au/forums/topic/120906-engine-start-button/
Where are you suppose to mount this? does it fit in the cigarette lighter slot?
The button is 21mm diameter and the unit needs 40mm space at the rear. So it will probably fit where the cigarette lighter is.
what about theft issues, once the theif is in your car they can start it with ease?? or is there sumthing that can stop them?? just thought id ask.
You still need to turn the key to on before the car can be started.
i bought this off Thomas with no quams and the instructions are pretty good on how to fit it. Even an idiot (like me) can do it. Just a note, it doesnt exactly fit into the cigarette lighter. Its slightly smaller but it does fit in.....just dont push too hard! But i have yet to try to put a layer of tape around it so its snug. So dont be scared to buy from Thomas cos he is in the Sweden. Good luck with the other one.
  • 1 month later...
  • 3 weeks later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
