RB26 D20423A
I ordered a motor and it is supposed to be R33 RB26DETT. Above is the engine number that i requested from them. Was wondering if anyone can tell me if it really is a 33. Specifically someone who has the FAST software and maybe they could run the number through it and let me know. Any help would be great. Thanks guys.
https://www.sau.com.au/forums/topic/120933-need-to-know-generation/
RB26 D20423A
My engine no is RB26 038604A from a late 93 R32.. Hope this also helps.
wrxhoon - any idea how to decode the numbers without NISSAN FAST software? Do these numbers mean anything?
I don't think you can tell with Nissan fast how old the engine is by the number.
I have a list of engine numbers and the aproximate built date . You are correct in saying your engine was built in the second half of 93.
How sure are you that it is out of a 32? Just wondering cause the company knows i am going to be checking to make sure it is a 33 and they assure me it is from an r33. Also the reason i want a 33 is so that I dont have to deal with the small crank collar on the early 32s but i also heard that later 32s might not have this problem. Is there any truth in any of this? thanks
The updated / larger crank collar was fitted to late model R32's. My engine was recently stripped down (late 93 model) and its obviously got the larger crank collar. Ask the company to take off oil pump and check the collar..
OLD R32 crank (90 model)
NEW R32 crank (my late 93 model)
I'm fairly sure but i can't be 100% sure ( according to my records its a 32, second half of 91 actualy).
Have you got a pic of the engine? The engine may be out of a 33 but originaly was in a 32, someone may have fitted it in a 33. Later 32's do have the 33 crank.
I am doing the swap myself so when i get the motor I will be taking off the oil pan anyway since I need to use the rb25 unit. Is it possible to tell visually by just removing the oil pan? either way I will take pictures and post them up on here of the crank collar. Also I was wondering if the engine number I listed is exactly correct. Should the D be a 0? I had some trouble reading the hand writing of the guy who gave it to me.
Edited by BlackRBS13
how do you find out when the engine was made?
is there a function in fast that allows you to input the engine number get out details?
im sure my engine didnt orignally come from my gtr, and was just wondering......
my number is 057289A
steve
Edited by PHATR32
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
