Hi guys,
It's been a while since our last updates of quality auctioned rim sets to suit various Nissans.
Here are a few listings of what's currently available on the Yahoo auctions.
We will be updating this list constantly as the rims become available.
Volk TE37 in silver. for GT-R
18x9.5 +12 all round
fitted with RE01 265/35/18 rubber sporting 7mm of tread left.
slight scuff on one rim.
apologies for the lack of clearer pics.
This set's bidding closes on 6th june
Estimating a landed price of $3400
VolkTE37 06 model.
brand new. No need to wait for production.
can land these for $3990
auction closes 9th june
Work Meister S1 (2P)
18x9.5 +20 all round
AD07 235/40 and GP 265/35 rubber attached. 6mm tread.
auction closes 7th June.
we can have the scuffs professionally machined clean.
$3600 landed.
Nismo LMGT3 to suit GT-R
18x10 +26
rims only. Auction closes 7th June
clean set of rims. caps included.
will land for $2620
Gramlights57F Pro
18x7.5 +30 fronts
18x8 +34 rears
Potenza GIII rubber attached.
auction closes 8th June
very nice condition
Expected to land for $2500 to $2650 depending on bids.
INPUL NS-GT
18x8.5 +35 fronts
18x9.5 +38 rears
originally fitted to a Z32 but has many applications.
tyres fitted w/ 5mm rubber
one slight dent on one rim only
auction ends 9th june
expected to land for $2200
If we do not list what you are seeking, let us know what you are looking for and we will do our best to locate it.
:laugh:
CE28N in a custom white with pearl blue
18x8.5 +25
18x9.5 +28
Potenza GIII attached.
good condition.
Bids close 11th June
Can land for as little as $3200 if the bids go well.
Volk GT-N to suit Supra
fitted with Pirelli Rosso rubber.
immaculate condition
18x9 +41 fronts
18x10 +43 rears
Can land for as little as $2550 if the bidding is on our side.
bids close june 10th
  • 3 weeks later...
Hi mate,
Any chance of getting a staggered set of 18" Work Meister S1's (2P) to suit a R33 GTS25t (preferably w/ alloy centre and polished dish) in good condition through an auction?
If not, is there anything else available with some dish that you could recommend in 18" for a Silver R33?
Thanks :glare:
Hi mate,
Thanks :whistling:
Bump :)
Cheers mate :D
I'm kinda set on getting the Meisters, but feel free to make any other suggestions if you see something that you think is good value and would suit a silver R33.
i guess there's this set on auction as we speak.
These may be a tight fit though.
Work Meister S1 3p
19x9 +36
19x10 +35
114.3 5 hole.
Suitable for Supra or similar.
Potenza GIII rubber included.
PM for pricing.
Work Meister S1 3p
19x9 +36
19x10 +35
114.3 5 hole.
PM for pricing.
Nice, but too big for me :ermm:
Would you be able to get me a rough price for a set of Work Equip 17" to suit a series 4 rx7?
Do these come about much on the auctions?
Prob best to shoot me a PM to answer this one as Im not on the forum much.
Cheers.
ali-turko
Everything in stock at this stage is 9.5 wide.
We can find something that suits no probs. Will need to know what budget to work with.
PM me and we will work out some options for you.
:P
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
