crystal tail lights may not suit a 31 man
i sort of agree with you but im just curious on what it would look like although the import ass end does look good standard ive had the car 6 years now and was thinking of changing the look
get some old style wheels with massive offset and stretched tyres, and then lower it so it tucks tyre.
you can order those performance alloys watanabe rip off's in nearly any size you want... get some 15 X 10's 0 offset.
hotness
hotness
yeah ive got an old style deepdish 2 piece rim off a gts-x and as for the lowering ive already got adjustable koni shocks with lowered kings its pretty much the lowest 31 around well one of and people hate me for it so its wound up at the moment just above the tyre line
led conversion might be cool, without the 'ice'. would be a custom job though ive never heard of anyone making r31 ice bling taillights.
projector headlights, white out the black striping (or remove) and put a front lip on it with decent front bar. that way itll look better. ice taillights are the automotive worlds way of showing off your bad taste.
If you can understand Japanese, or have a translation program, somewhere in the R31House.co.jp site there are some pics of an R31 with LED tail lamps. They look exactally like the standard tail lamps, but once lit up the LED's look awesome.
Unfortunatly, their site has changed, and with me being unable to read japanese I have no idea what I am looking at.
**EDIT** I found a pic.....not the best but all I can find!
Edited by NismoR31Jet
cheers mate i think u have seen them on that site ive also seen one skyline down the coast like that it looked good. if you want to fet in to r31 house go to http://babelfish.altavista.com/ and tranlate r31house.co.jp it will bring the whole site up in english :dry:
hotplates ftw
that's what the 'lines are known for, i see absolutely no reason to change it to try and be (apparently) cooler.
try an R30 taillight conversion if possible :D
im not trying to be cooler :) as you put it but if you had a car for six years you would want a change too, your coment on the want to be cooler part is so missled i want to be different not cool :P
ok sorry not quite cooler then, different eh...
sell it and buy a DR30! :D now that's different...
i was thinking about doing the opposite (selling it and buying a 31) but that's not financially possible at the mo' :(
id love to have a dr30 too but i cant part with it if i did it would be near impossible to find another one there getting quite rare i cant even find interior parts as the model i have which is the straight gts 1987. i could imagine how hard it would be to get parts for a dr as im led to believe there even rarer, the import rs that is :D
oh yeah its rare as anything, and expensive too. there are some shops in japan that stock some parts but u can imagine the hassle in that :blink:
yep thats the price we pay for having rare cars but its worth it all the same. and it is a hassle getting stuff from japan when your just an everyday person and not a company that can import in bulk :
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
