keen to sell now,any offers? can give you the details of my mechanic who is willing to do a manual conversion on this car very cheap if someone buys it!
jay 0410477413
  • 3 weeks later...
can supply a manual box for it as well,and the details of a mechanic who will do thw conversion CHEAP!!
(same one that did all the engine work)
  • 3 weeks later...
ANY SERIOUS OFFERS CONSIDERED.WILL CONSIDER TRADES,BUT WOULD RATHER JUST SELL IT.
I CAN TAKE THINGS OFF TO REDUCE PRICE IF YOUR WORKING TO A BUDGET.
I COULD ALSO GET THE MANUAL CONVERSION DONE FOR YOU IF A DEPOSIT WAS TAKEN AND PRICE WAS AGREED ON.
jAY 47 245555(PENRITH NISSAN) MOB 0410477413
the car is a 1996 RS4 Stagea RB25 awd Wagon features are
Factory fitted black leather interior
350z 18" track wheels
pioneer head unit
all original factory mats including rear boot mat
tow bar!!!!
cargo blind
ENGINE MODS-
GT35R garrett turbo
custom made high mount stainless manifold
38mm Tial external wastegate
720cc injectors
sard fuel reg
HALTECH E11 engine managment
boshe fuel pump
gates racing timing belt
tommy metal head gasket
ARB head bolts
shift kit in the auto box
custom alloy intercooler piping
front mount
turbosmart mega sonic BOV
turbosmart duel stage boost(9/15psi)
spitfire ignition coils
3" turbo back exhaust
this car owes me in excess of $50'000!! it has 81'000kms on it and has done 3000kms since all of this work was done.i also havce all of the stock bits along with the factory wheels with new tyres on them.it was tuned at HALTECH by an ex staff member and made 258kw at all four wheels at 14psi.
i was asking $26'500,but all offers would be considered.
i would also consider a trade of an R34 gtt man coupe plus cash your way(in stock condition)
give me a call at work (PENRITH nissan) on 02 47245555 or mobile after hours on 0410477413
Cheers Jay
PRICE DROP $21000...............TRADES CONSIDERED.
pioneer head unit
tow bar!!!!
cargo blind
ENGINE MODS-
GT35R garrett turbo
720cc injectors
sard fuel reg
boshe fuel pump
ARB head bolts
front mount
Cheers Jay
bump
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
